This discussion topic has been answered Discussion topic: Upgrade to swap device
Message posted on 09 Mar 2026 08:48 PM
Message posted on 09 Mar 2026 09:16 PM
Hi @Kylie89 if this keeps happening then call sky on 150 for help with your order.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 09 Mar 2026 11:15 PM
Re: Upgrade to swap device
Yes i will have to theyre a nightmare to get hold of. Thankyou
Message posted on 19 Mar 2026 03:41 AM
I can't upgrade so many times o try but can't upgrade actually I don't know lot of time i have did follow instruction but can't upgrade right now should i do
Message posted on 19 Mar 2026 03:51 AM
What's happening when you try? Are you failing the credit checks?
Message posted on 16 Apr 2026 02:09 AM
Upgrade my device but I can't my credit unsuccessfully showing me bu why
Message posted on 16 Apr 2026 06:30 AM
Hi @Tuhin1 if you are failing the credit checks there is nothing you can do other than use a credit agency to try and see why. Sky or anyone here won't be able to tell you why. Repeated attempts and failures will make it worse.
