Discussion topic: Upgrade my phone and keep current device and sim
Message posted on 22 Jun 2024 06:14 PM
Hi. I'd like to upgrade to the 15 pro max. I currently have a 13 pro max but I want to keep that too. I was wondering how much of my contract is left and if the new phone would be unlocked. Because in this current phone the phone is a sky contract with my old giffgaff sim which I'd like to keep. So I'm basically trying to get the 15 pro max and want to be able to use my giffgaff sim.
Message posted on 22 Jun 2024 06:23 PM - last edited: 22 Jun 2024 06:25 PM
Re: Upgrade my phone and keep current device and sim
In that case you don't go the upgrade/swap option route, simply buy a new device. All Sky mobiles are unlocked.
You'll need to check when you took out the contract within the message centre, no one on the forum will know.
Message posted on 22 Jun 2024 07:27 PM
@Farhaan2k wrote:...if the new phone would be unlocked.
There's no 'unlocking' - if you want a new device then as described you simply buy it and pay for two phones. (Subject to passing credit check)
