Discussion topic: Sky mobile
This message was authored by: Sherwan
Sky mobile
Tried to buy a iPhone 15 pro max but it doesn't let me every time I go to the check out it doesn't show me anything else
Re: Sky mobile
@Sherwan
If that  continues you'll need to call Sky and an agent will place the order for you.
Re: Sky mobile
@Sherwan
Have you tried using a different web browser or device, if you have and the same happens then call Sky for help.
150 is the free number to use from a Sky Mobile or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
When you do call say nothing when the bot speaks to you about what your call is about as it should then route you to somebody.
