Discussion topic: Unable to make or receive calls in Greece using hotel WiFi
This message was authored by: Doll_Face
We're on holiday in Greece. We have an emergency at home in the uk. I am unable to make or receive calls from my mobile using the hotel's WiFi, we can only call via WhatsApp. However I need to make & recieve calls to/from those not on WhatsApp .
please can anyone help?
Thank you 🙏🏼
Re: Unable to make or receive calls in Greece using hotel WiFi
@Doll_Face
You could try turning off automatic network selection in the settings then get your phone to search for other available networks to see if it will then connect and allow you to make calls. Also make sure the spend cap hasn't been reached if you have one set.
Hi @Doll_Face  have you turned on roaming and mobile data in your phone settings ? Have you checked you haven't reached either of the roaming or monthly spend caps ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
