Discussion topic: Sky mobile swap returns label
Message posted on 24 Jul 2024 04:12 PM
Hi it might sound like a silly question, but the returns label that comes inside the swap box... where do I stick it on the box? Should I put it over the existing label on the box used to send to me or on the bottom of the box?? Don't want to get it wrong!
Message posted on 24 Jul 2024 04:15 PM - last edited: 24 Jul 2024 04:15 PM
Re: Sky mobile swap returns label
@Hannah989 put it Over existing label
I would put it over the label that is addressed to you otherwise you might end up with it again !
