Discussion topic: Sky mobile swap returns label
This message was authored by: Hannah989
Hi it might sound like a silly question, but the returns label that comes inside the swap box... where do I stick it on the box? Should I put it over the existing label on the box used to send to me or on the bottom of the box?? Don't want to get it wrong!
Re: Sky mobile swap returns label
@Hannah989  put it Over existing label
I would put it over the label that is addressed to you otherwise you might end up with it again !
