8
This discussion topic has been answered Discussion topic: Signal
This message was authored by: Neildad
Signal
Why is my phone signal so bad , even when I'm on 5g I can't load work stuff yet my work friend can on a different network this happens everyday and everywhere inside the m25
Avatar for Neildad
This message was authored by: Neildad Answer
Re: Signal
This message was authored by: CanardNoir
Re: Signal
You are not alone.
I have the same problem. The coverage map suggests I have good coverage. In fact, I have almost no coverage. I can sometimes get one bar if I stand on one leg in the wardrobe in the spare bedroom and the wind is in the right direction. There are at least three masts in our village but I'm guessing they're not there for our benefit rather for the M1 and M25 that run nearby.
Sky keep repeating that there is nothing wrong and continue to show good coverage on their website. I conclude that they cannot be trusted and value being economical with the truth in their marketing rather than taking good care of their customers.
I'm researching other providers but have similar doubts about their claims.
Avatar for Neildad
Re: Signal
Thinking about swapping providers as well my friend , I was wondering if coverage was due to work being carried out on masks but as I said , my work collage always has a reasonably good signal
Re: Signal
Bear in mind Sky Mobile uses the O2 network so if you're experiencing a poor signal in your area and looking to change network, you will also want to avoid O2/Tesco/GiffGaff.
Re: Signal
Great tip there!
Knocked O2 off my list.
Avatar for Neildad
Re: Signal
This message was authored by: Crobs012
Re: Signal
Hello, are you still having this issue as I've recently joined sky mobile and I'm facing the same problem
Avatar for Neildad
Re: Signal
I'm a afraid I left sky mobile I have joined EE MOBILE and must say the signal is 100 percent better
Avatar for Neildad
Re: Signal
Hi I left sky mobile and joined ee mobile the signal is 100 times better
