Discussion topic: Signal problems
This message was authored by: Mcl53
Message posted on 13 Dec 2025 03:19 PM
Signal problems
Ever since september ive had signal problems with my phone since the mast was deliberatly set on fire in lochgelly how can i get help with this
Find out more
Message posted on 13 Dec 2025 03:24 PM
Re: Signal problems
Hi @Mcl53 if there is a fault with the mast then there isn't much you can do but wait. Sky don't own the masts so are relying on others for that. Once fixed if you call sky they may give you some credit as compensation.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
