Discussion topic: Signal dropping in and out
This message was authored by: CBred
My phone signal keeps dropping in and out all the time while outside Sometimes I get full signal and can make calls etc but other times it's week or no signal and I can't use my phone and I can't be contacted.
Re: Signal dropping in and out
Hi @CBred  any issues showing ?
https://www.sky.com/help/articles/service-status-sky-mobile
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for CBred
It says a mast is being worked on but it said this since before Christmas when my issues started. Also my partner is also with Sky Mobile and has no issues. Would that mean it's my actual phone?
It could be @CBred  but I would wait til the mast problem is sorted before changing your phone unless it's a very old phone and you were planning on changing now anyway.
Avatar for CBred
OK I'll do that. Do you know who to contact to find out how long it might take for the mast as its been over a month already with really bad signal and I'm missing important phonecalls so I kind of need to know how long I need to wait before it's fixed. Thank you for your help!
@CBred
It's worth noting as well that Sky don't own or maintain any mobile phone masts so you, and anyone else possibly being affected, will be waiting on a third party repair.
