2
This discussion topic has been answered Discussion topic: Roaming passport
This message was authored by: Pete218
Roaming passport
We keep getting this text every morning while in France.
mare we being charged £2 a day
Hi. Your Roaming Passport Plus will end on 02/03/2026 at 09:19 UK time. If it's re-activated, we'll add a £2 charge to your next bill. If you exceed the 25GB fair usage limit across Roaming Passport Plus destinations, you'll be charged per GB (pro-rated) for the rest of your bill period. To avoid more charges, turn off data roaming and avoid calls or SMS. Learn more at
This message was authored by: 63johnw Answer
Re: Roaming passport
Hi @Pete218  yes that's the standard text message from sky when you are roaming. Is there an issue you are having.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@Pete218
The text is telling you that you are being charged £2 per 24 hours and whatbri
e it ends.
