This discussion topic has been answered Discussion topic: Roaming charges
Message posted on 20 Oct 2025 05:42 PM
I am currently in Tunisia. I turned mobile data off and set spending caps to both mine and my daughters phones. One sim has racked up a £200 bill but the other hasn't. The spend cap was on ahead of arriving here. Any idea how this has happened?
thanks
Message posted on 20 Oct 2025 05:47 PM
Hi @NP221 if you didn't turn off mobile data and roaming then turning on flight mode before leaving the UK then the phone will have connected to the local network and started using data. If you are sure spending caps were set for all individual sims then you will need to dispute the charges with sky when you return to the UK.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 20 Oct 2025 05:59 PM
Re: Roaming charges
I have had these texts when I first arrived which said a spend caps was put in place. But have since checked my future estimated bill which is £200 more
Message posted on 20 Oct 2025 06:02 PM
Re: Roaming charges
The picture will show after moderation @NP221 Have you checked each sim in the account for the caps ? Each sim will have its own.
Message posted on 20 Oct 2025 06:04 PM
Re: Roaming charges
Yes checked both sims. One has £200 and the other £0.
both had £0 caps applied by me before leaving the UK, then received texts when landing saying it had changed to £45. Wasn't able to send messages until in WiFi and when WiFi disconnects phone doesn't work
Message posted on 20 Oct 2025 06:07 PM
Re: Roaming charges
Did you set it at £0 @NP221 or was it turned off ? Looks like you will need to dispute this with sky when you return to the UK.
Message posted on 20 Oct 2025 06:11 PM
Re: Roaming charges
Yes I set it at £0. When checking my usage it says £200 used on the 17th which is the day I arrived and nothing since.
useless - what is the point in having spend caps if they don't stick to them. And then putting their own spend caps on and it still exceeding that
Message posted on 20 Oct 2025 06:28 PM
Re: Roaming charges
I think you should have a good argument for getting these charges reversed @NP221
