Discussion topic: Roaming calls and texts
This message was authored by: kiean08
What do I have to do to be able to get the passport roaming for £2 for 24hours whilst in spain
Re: Roaming calls and texts
Hi @kiean08  you have roaming and mobile data active in your phones settings then when you make a call, send a text or use a small amount of data it kicks in automatically.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@kiean08
For Spain it should cost you £2 for each 24 hours use of your home allowance. You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage due to overuse.
