Discussion topic: Roaming Passport Plus Stopped working
Message posted on 28 Aug 2024 01:47 PM
Hi
I've been in US for around a week and my roaming passport has suddenly stopped working. I received a welcome text and everything was working fine, but now can't send receive texts or make calls. I keeping getting a pop up saying refreshing sim data. Can anyone help please.
Message posted on 28 Aug 2024 01:54 PM
Re: Roaming Passport Plus Stopped working
Although you don't have to have it set do you have a spending cap set and if you do is it high enough to cover you stay at £2 per day ?
Failing that have you done a manual search for all available networks to see if your device will connect to a diffeeent one that then works ?
Message posted on 28 Aug 2024 03:51 PM
I had to restart my phone a couple of times.
(But check the spend cap as above)
