Discussion topic: Return mobile phone
This message was authored by: Sam2774
Return mobile phone
I have tried multiple times to get a returns label to return my mobile phone with in the 14 days cooling off period and this seems to be impossible.      I have failed to speak to a human being
I have gone through the automated contact requested label by email never came.
I need to speak with a human being in sky how can I do this
Re: Return mobile phone
@Sam2774
These are the current methods for contacting Sky. Depending on the reason for making contact some methods will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
▪️I AM NOT A SKY EMPLOYEE ▪️
