Discussion topic: Replacement Sim card if phone not working
This message was authored by: Paula113
How do I get a new sim card if after trouble shooting says I need a new one. And I cannot ring up as my sim card is damaged.
Re: Replacement Sim card if phone not working
Hi @Paula113  you could try the social media links at the bottom of this page but usually replacement sims can only be ordered by calling sky.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Paula113
Thanks bit of a system fail on sky's part when the problem is my phone won't work  then why not phone us, wish I could. The site is so hard to navigate, but will try the links.
This message was authored by: Lindacarnie
I cannot call direct as my SIM cArd is Not working I need it replaced asap,or I will cancel my accoun t with you
@Lindacarnie
You are not talking to Sky as we are customers like you so if you can't call then you can also contact Sky via social media:
https://helpforum.sky.com/t5/Online-Apps-Email/Want-to-private-message-Sky/ba-p/4895295
