6
This discussion topic has been answered Discussion topic: Reference number
This message was authored by: Abi__
Reference number
Evening,
I ordered an Iphone 16 and it says it is going to be delivered this friday.
When i click on the link to track order through DPD, it shows an order that was delivered in April?
I have never ordered through sky before so quite confused, I have downloaded the DPD app and inserted the unique tracking number SKY sent me through email however it shows that previous order.
Has this happened to anyone before?
Re: Reference number
@Abi__
What shows via your Sky account here:
https://www.sky.com/ordertracking
It will not show via DPD until they have your order which they might not do just yet so this might be why you are seeing your previous order.
@Abi__
Avatar for Abi__
Thank you for your reply!
I have never ever ordered through sky before, i am on the phone with them right now so will update with result.
Avatar for Abi__
Just rang sky, they said there was a technical issue and it has been brought to a higher team member.
They said to expect the new tracking reference either tonight or tomorrow, so fingers crossed.
This message was authored by: Hanwa32
Hi,
Did you get your order? I'm having the exact same issue at the moment
Avatar for Abi__
Hey! Yes i did.
They will send you the right reference number closer to your order. 🙂
Mine came on the date it was supposed to, perfect condition.
Hope this helps you!
Avatar for Abi__
@Hanwa32
Hey! Yes i did.
