Discussion topic: Re: Phone not working abroad
This message was authored by Maryport1966 This message was authored by: Maryport1966
Message saying 'not registered on network'.
Tried all the online help and can't ring sky for help.
Also getting a message constantly saying 'updating Sim data,.
I enter my mobile number but then keeps asking.
Has this just started to happen or is it because you are abroad ?
Why are where are you entering your number as we need more information to figure out what is happening ?
Maryport1966
It's just started as we have landed abroad
Do you have roaming turned on, this can usually be found under data options.
Maryport1966
Yes day roaming is on
Have you tried getting your device to search for other networks to see if it will connect to any ?
Maryport1966
Yes. There are 3 options and none work. Says your Sim card does not allow
Maryport1966
Looked on Sim manager and says " no Sim card', but I have one inserted. Doing the extract same on my husbands phone.
This message was authored by 63johnw This message was authored by: 63johnw
Hi @Maryport1966  what country are you in as there are issues in Spain and Lanzarote with sky mobile that sky are looking at.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Maryport1966
We are in Fuertevetura, Spain 🙈
This message was authored by Flinttas This message was authored by: Flinttas
Same with me. Landed in Fuerteventura a few days ago, network connected, sky charged me £2 then network connection stopped working. Phone kept over heating as it tried to find a network that it could connect to. To no avail and now it says emergency only calls. It also couldn't get the correct time as it seemed to be trying to suggest I was in Spain, Madrid, so I had to manually adjust to Canary islands!
When I get home I am going to look at moving to another network provider.
Maryport1966
We are home now,  but we never resolved the problem.  Like you we got the sky charge message but then no service following the message.  Constantly saying emergency calls only.
Well I have had no luck on forums and have written to sky but no response. However, I have tried switching to 2g connection and I got connected. I got a junk text from Howdens come through so that will now cost me!
I have set it back to automatic, it stayed connected for about 2 mins after suggesting there was a 4g connection  now has lost connection again!!!!
Hi @Flinttas  just for information it doesn't cost you to receive text messages, that won't trigger the £2 daily charge either.
I wouldn't put it past sky though 😉
Btw, for anyone else still not connecting I have set my phone for just 3g (I did initially set 2g then switched to 3g in case you need to go through that process but don't let it auto select), it connected to the Orange network and it has now stayed connected for at least half hour. Even my network time is correct and I don't have to force it to be canary islands and mot Madrid. Fingers crossed this will remain now until I get back home.
