Discussion topic: Preparing old phone for swap
This message was authored by: downwithsky
Should I just restore to factory setting to prepare my old phone to swap. Do I need to do anything else ?
Re: Preparing old phone for swap
Hi @downwithsky  that should be enough. Find my iPhone should be deactivated if it's an iPhone.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for downwithsky
thank you I have erased tings and now when I switch it on itgoes straight to the hello page. will that do?
If you have done  a factory reset then it would start up at the hello screen so what you have done is fine as it is back to the state that it was when you first got it.
Yes @downwithsky  that should do.
