Discussion topic: Phone
This message was authored by: Nicol6
Message posted on 07 Mar 2026 09:22 AM
Phone
I have very recently moved to sky for my mobile provider, I have an iPhone 14, and on a sim only deal, I can text but not make calls, I can receive calls, any idea? Thank you
Find out more
Message posted on 07 Mar 2026 09:44 AM
Re: Phone
Try refreshing the network settings so go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
