7
This discussion topic has been answered Discussion topic: Overseas and no connection
This message was authored by: Ray+Morton
I am in Greece.  I get the daily Sky Passport message.  But I can't connect to any networks.  I can't see sky as a possible network.
Restarted 5 times.
Changed from autoconnect to manual and back
Reset network connections
Re: Overseas and no connection
@Ray+Morton
If you've very recently returned from abroad try this
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
You won't.  You have to select a local provider.
Avatar for Ray+Morton
Still no answer. Have spoken to Sky and nothing.
Flew home last night. No connection, no response from Sky.
Hi @Ray+Morton are you saying you have no connection back in the UK ?
All Opinions Are My Own
Yes.  I can see the Sky network, but it won't let me connect to this or any other network.  I think i is an account problem.
@Ray+Morton
Apple:
Android:
You are a genius.  You have no idea how much that has just helped me.  Thank you.
