This discussion topic has been answered Discussion topic: Overseas and no connection
Message posted on 22 Aug 2024 10:45 AM
I am in Greece. I get the daily Sky Passport message. But I can't connect to any networks. I can't see sky as a possible network.
Restarted 5 times.
Changed from autoconnect to manual and back
Reset network connections
Message posted on 24 Aug 2024 08:45 AM
If you've very recently returned from abroad try this
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
Message posted on 22 Aug 2024 11:01 AM
Re: Overseas and no connection
@Ray+Morton wrote:I can't see sky as a possible network.
You won't. You have to select a local provider.
Message posted on 23 Aug 2024 03:25 PM
Still no answer. Have spoken to Sky and nothing.
Message posted on 24 Aug 2024 08:02 AM
Flew home last night. No connection, no response from Sky.
Message posted on 24 Aug 2024 08:09 AM
Hi @Ray+Morton are you saying you have no connection back in the UK ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 24 Aug 2024 08:35 AM
Yes. I can see the Sky network, but it won't let me connect to this or any other network. I think i is an account problem.
Apple:
Android:
Message posted on 24 Aug 2024 09:02 AM
You are a genius. You have no idea how much that has just helped me. Thank you.
