Discussion topic: Order
This message was authored by: Liviu1
Order
Why was my order canceled?
Re: Order
@Liviu1
It’s possible you may have failed the required (enhanced) credit check(s). Emails which confirm or cancel the order sometimes arrive out of sequence. See this link for Skys guidance ~
https://www.sky.com/help/articles/credit-checks-sky-mobile
Be aware that if you keep trying to order the device this could further impact your credit score. If you contact Sky they would be able to confirm that’s the reason your order was cancelled but not why you failed the credit check in the first place as they are not allowed to view your credit record. You would have to sign up to a credit reference agency like Experian or Equifax, which would give you access to your credit record.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to call Sky to chase it up.
