Discussion topic: Not registered on network
This message was authored by: Kittensocks
Message posted on 05 Jul 2026 09:40 AM
I have done all the usual things like turning on and off phone, cleaning simple, boggling flight mode but still get.the message not registered on network..any help appreciated. Thank you
Find out more
Message posted on 05 Jul 2026 09:48 AM
Re: Not registered on network
Does your phone have a physical sim as opposed to an esim, if so are you able to try it in another unlocked phone to see what happens because if it doesn't work in another one then it might have developed a fault so you would need a replacement.
