This discussion topic has been answered Discussion topic: Not registered on Network
Message posted on 20 Jul 2024 07:29 AM
My Samsung Galaxyphone can no longer make or receive calls or texts. The message "Not registered on network" is displayed.
I have followed all the trouble shooting steps detailed without any luck. Placing my wife's Tesco Sim in the phone enables it to make calls and send texts fine.
It seems a replacement SIM card is needed, but how do I order one please?
Thank you for your help.
Mark
Message posted on 20 Jul 2024 08:57 AM
To answer my own question, I called Sky (using my wife's phone) when the departement re-opened this morning and a very helpful lady called Ann ordered a replacement SIM card for me.
Fingers crossed
Mark
Fingers crossed
Mark
Message posted on 20 Jul 2024 09:00 AM
Re: Not registered on Network
Hi, what number did you use? I'm having the same problems- very difficult as I'm on call this morning so having to swap to an old battered phone.
I can't tell if it's a problem with the service or my phone, as it's been intermittant the last day or so
Message posted on 06 Oct 2024 08:34 PM
What i did with this problem,
Open "SIM Toolkit" apk
Then "Roaming"
Select "Automatic"
Wait for sim restart (1-2sec)
Should be ok. Works fine for me
