5
This discussion topic has been answered Discussion topic: Not happy with iPhone 15 pro max
This message was authored by: Camjoel44
Hi. I stupidly got an iPhone 15 pro max in May this year moving from Android. Biggest mistake ever. Is there any way I can sell the phone and get another phone if I keep up paying the contract?  Any help greatly appreciated. Well looking for an answer from a sky worker if possible like Lisa_P18 or something like that
This message was authored by: PandJ2020 Answer
Re: Not happy with iPhone 15 pro max
@Camjoel44 wrote:
I am tied in for 2 years
You're not.
You can either clear the outstanding balance or continue to pay - if you default on payments then the full amount becomes immediately payable and recovery actions will commence.  (You don't have to keep the device)
Alternatively, you can ask Sky for a Swap - you can swap back to an Android but the residual value of your phone is going to be significantly less than the credit you owe on it (it loses a lot initially and probably further impacted by the new iPhone coming in a matter of weeks).  If you swap then the difference (which is likely to be hundreds of pounds) becomes immediately payable at the next bill.
Of course, any purchase will involve a credit check which isn't guaranteed.
This message was authored by: chris+f
What issue do you have with the 15 pro max ?
It is unlikely Sky will respond to you.
As long as you keep paying for it each month then you should be OK to do this.
Avatar for Camjoel44
I have been Android for years and clever me thought it would be good changing to iPhone..... Big mistake. I should just stick to what I know. I am tied in for 2 years
You're not.
Thanks for all the advice everyone. I should have just stuck to Android. Lesson truly learned
