Discussion topic: Not accepting post code
This message was authored by: EvanM1
I'm trying to set up my sim but it's not accepting my eircode as it says post code is invalid
Re: Not accepting post code
@EvanM1
You will have to find a way to contact Sky Ireland about this, 150 is the number to use to call them on if you have another phone that has a Sky sim in it.
Avatar for EvanM1
I don't have any sky sims how will I contact them?
Social media ?
As there are links at the bottom of the page, they are also on Facebook messenger.
Avatar for EvanM1
Is there a number I can ring for sky Ireland
Sky are not making it easy to find phone numbers at present so under “Need more help” if it is available should be the number to use, just make sure the flag bottom right is set to Ireland:
https://www.sky.com/help
Avatar for EvanM1
I have read all of the help articles and none of them can help me, I've seen other posts about this and they had to get in contact with an employee from sky
@EvanM1
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note As you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Avatar for EvanM1
I have tried the sky help tool but I just keep getting directed back to here
Escalations are currently closed due to an issue with them and at present there is no known date when they will be available again.
Avatar for EvanM1
How can I set up my SIM card if there's a common problem for customers in Ireland on Eircodes not being accepted?
As customers here there is nothing we can suggest that what we haven't said already - contact Sky Ireland for help.
Avatar for EvanM1
I have tried all of the methods and nobody is able to help me
