Discussion topic: No sky mobile in US! ??
This message was authored by: Ar73
Message posted on 31 Dec 2024 02:27 AM
Not able to make or receive calls or sms in US on sky mobile
Find out more
Message posted on 31 Dec 2024 08:44 AM
Re: No sky mobile in US! ??
Hi @Ar73 from sky
You'll need a compatible phone to use calls and texts or contact the emergency services while you're in the USA.
To check if your phone is compatible and find out more, go to Roaming in the USA."
also try setting your monthly cap high enough to cover your stay. Also try turning off automatic network selection in your phone settings, then do a manual search and try different networks on the list. Restarting your phone sometimes helps.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
