Discussion topic: No signal in doors
This message was authored by: maymay
Message posted on 30 Oct 2024 12:17 PM
No signal in doors
Can't get a signal indoors works out side no mast problems so what is happening.
Find out more
Message posted on 30 Oct 2024 01:08 PM
Re: No signal in doors
Hi @maymay it could be you are on the edge of a good reception area then once you go inside then the signal is struggling to get through your walls. If it's working outside and there are issues in your area then there is little you can do other than use WiFi in your house and activate WiFi calling if your phone is supported.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
