Discussion topic: No network connection thailand
This message was authored by: Dave382
I am currently in thailand and had signal for the first week or two on my sky mobile esim but for the past 3 weeks have had no network connection. I have tried following the guides online but none of the solutions worked. I tried reinstalling my esim but was unable to make a network connection to do so. Any idea on how i can fix this?
Re: No network connection thailand
@Dave382 l
What phone do you have ?
@Dave382
Thailand is a Rest Of The World destination so using your Sky sim there will be very expensive. Could you have reached the spend cap?
Avatar for Dave382
iPhone 15 plus
Avatar for Dave382
@Daniel0210 im not using it for data roaming simply just need to receive 2FA messages. I have a physical Thai sim I'm using for data. It doesn't have any bars of service whatsoever now just says no service as if it can't connect to any of the local networks
Try going through this:
https://www.sky.com/help/articles/sky-mobile-roaming-problems-no-signal-apple
Avatar for Dave382
@caesarome Yeah thanks, that's the guide I followed but had no luck
