Discussion topic: No mobile signal
This message was authored by BLondon77 This message was authored by: BLondon77
No mobile signal
I had a couple of days of signal but now nothing. Spend caps checked turned phone off etc. still nothing.
Re: No mobile signal
If you are in the UK then spend caps don't apply.
If you are abroad and have a spend cap set is it enough to cover your stay ?
Have you tried manually searching for networks to see if your device will connect to one ?
BLondon77
Thank you I am abroad. Spending cap is well over and data roaming cap. I tried selecting the network but still nothing.  I had to change the spending cap but will not allow me to send a text or call to reactivate. How do I reach sky from abroad?
They can be contacted via social media as there are links to their sites at the bottom of this page.
