Discussion topic: No mobile connection in Austria
This message was authored by JMS01 This message was authored by: JMS01
I'm trying to connect to any mobile network in Austria but nothing is working. I've tried the full set of suggestions in the Sky mobile help guides and checked all the settings. Not sure what to try next as I have no phone signal to contact Sky.
Re: No mobile connection in Austria
Have you a spend cap set and is it enough to cover your stay in the country ?
Have you tried searching for other available networks to see if you can connect to one of them ?
JMS01
Thanks - n
JMS01
Thanks. I don't have a spend cap and when I try to look for networks the phone won't find any.
This message was authored by 63johnw This message was authored by: 63johnw
Hi @JMS01  sky have informed us previously that a spend cap must be set, it can't be zero.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
JMS01
Thanks. I had a spend cap set when I arrived. I turned the monthly spend cap Off following one of the Sky guides - I have tried to set one now but am getting an error message that the spend cap cannot be updated.
