Discussion topic: No connection when data is turned on
This message was authored by: gregs999
When I turn my data on it still says no connection, not allowing me to use any apps requiring data
Re: No connection when data is turned on
@gregs999
Are you able to make calls and send texts ?
Avatar for gregs999
Yes anything without data is fine just anything requiring data signal does not work
@gregs999
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
