Discussion topic: No Calls In, No calls Out. Getting Not Registered on Network message when i select Sky
Message posted on 23 Jul 2025 11:02 AM
Since Monday when i returned from France I have been unable to make ingoing or outgoing calls. when i try i get the message Not Registered on Network. when I try to select Sky from the available networks list i get the message Unable to Connect try later. I've tried all the suggested soltions on the Sky website but to no avail. Whats is my brain not seeing?
Message posted on 23 Jul 2025 11:07 AM
Re: No Calls In, No calls Out. Getting Not Registered on Network message when i select Sky
If you've very recently returned from abroad try this
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
Message posted on 23 Jul 2025 11:44 AM
Thanks for this. However I cannot find the tabs you refer to on my Samsng A54. However under SIM Manager it says SIM 1 Unknown Number. `could thid be the problem? On My Sky it only has my old A20e listed
Message posted on 23 Jul 2025 01:00 PM
That could well be your issue so are you able to add the number ?
Message posted on 20 Mar 2026 01:58 PM
I have tried but I cannot receive or call out
Message posted on 20 Mar 2026 02:24 PM
I have tried everything but I still cannot make or receive any calls
