Discussion topic: No Calls In, No calls Out. Getting Not Registered on Network message when i select Sky
This message was authored by: Adrian1st-24
 Since Monday when i returned from France I have been unable to make ingoing or outgoing calls. when i try i get the message Not Registered on Network. when I try to select Sky from the available networks list i get the message Unable to Connect try later. I've tried all the suggested soltions on the Sky website but to no avail. Whats is my  brain not seeing?
Re: No Calls In, No calls Out. Getting Not Registered on Network message when i select Sky
@Adrian1st-24
If you've very recently returned from abroad try this
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Adrian1st-24
Thanks for this. However I cannot find the tabs you refer to on my Samsng A54. However under SIM Manager it says SIM 1 Unknown Number. `could thid be the problem? On My Sky it only has my old A20e listed
@Adrian1st-24
That could well be your issue so are you able to add the number ?
This message was authored by: Richard361
I have tried but I cannot receive or call out
I have tried everything but I still cannot make or receive any calls
