Discussion topic: Mobile Swap double charge.
This message was authored by: Bif1
Not really a question ,just a heads up to anyone wanting to use the swap facility. Sky told me that if I swapped my phone, which was two years into a contract,  I could cash in and receive a new phone and continue to pay the same monthly price. I decided this was a good deal and I agreed the swap. Once the transaction was completed I was charged for both devices in a one month billing cycle. Guys be careful when you swap. Check when it is a good time in the month to swap to avoid doubling costs.
Re: Mobile Swap double charge.
While this is correct something else to factor in is when a phone is returned it is then inspected for damages and this can take 2-3 weeks during which you will still be billed for it.
Avatar for Bif1
Hi
Thank you for your time and consideration. Makes total sense. However Sky should have made this clear before I agreed the swap.
...but you will not be out of pocket as the extra payment reduces your overall credit balance.
This message was authored by: Tony+miffed
Same happened to me - tried to sort - employee hangs up - FORCED to take other actions as SKY refuse to sort
I did not notice doubl ebilling - for nearly two years - old phone never used
ZERO interest from Sky and impossible to talk to someone - they take an easy fix and make it a big problem
@Tony+miffed
Billing  for the returned phone should only happen if you owe an amount against it and if this is the case whatever is owed should be added to a future bill and only that bill so is this what happened ?
