2
This discussion topic has been answered Discussion topic: Network issue
This message was authored by: Jeetesh
Network issue
I am unable to register local network in India it was working ok few days ago now I am getting emergency call only
Re: Network issue
@Jeetesh
Have you hit your spend cap as it works out really expensive to use your mobile in India:
https://www.sky.com/help/articles/sky-mobile-roaming-rest-of-the-world
Roaming charges count towards your monthly spend cap. If your spend cap is set too low or set to £0, it will block you from using your phone abroad. To use data, calls and texts while you're away, check your spend cap limit at sky.com/spendcap.
Re: Network issue
@Jeetesh
Avatar for Jeetesh
Re: Network issue
I have cap on my mobile if I reach my cap I will not be able to make call or text,but I should receive text it's free to receive text
