Discussion topic: Mobile
Message posted on 14 Dec 2025 10:25 PM
Mobile
Hello, just want to see if anyone is having the same issue.
From around 8:30pm today I have been unable to use my data, make phone calls and send SMS text messages. Specifically, when I try and make a call I am met with the recorded announcement "Sorry we cannot connect this call, if you have set a spend cap...etc". I have made no changes to my sim and the other on my account works just fine.
Is anyone else experiencing this?
Message posted on 15 Dec 2025 05:34 AM
Re: Mobile
I would report this to Sky on 150 so they can look into this for you,
Message posted on 15 Dec 2025 07:13 AM
Re: Mobile
If you're unable to use your mobile to contact Sky these are the alternative methods and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
