04 Jan 2023 08:24 AM
Hi,
i have switched over from EE and kept my number however i cannot receive any calls! I had used the E sim option on the phone while i was waiting for the number to be switched across but now im stuck on not receiving calls. Any advice please?
04 Jan 2023 09:38 AM
Posted by a Superuser, not a Sky employee. Find out moreSky Mobile doesn't support Esims so is there anyway you can reverse what you did ?
While you are waiting for the number to change across you should still be able to use your EE sim as this should keep working then when it stops at this point you can start using your Sky sim.
04 Jan 2023 09:49 AM
hi @caesarome, i set up the new phone last week and it transferred everything over along with EE on 'E-sim' while i have been waiting for my number to transfer over. I have checked my sky this morning and the number has changed to the number i have transferred however i have not received a text or notification to say this has been completed so this is maybe why?
I can text, call using the transferred number but cannot receive any calls. My EE sim now does not work. I have removed the esim from this phone now. I have full signal etc on Sky on the phone so not sure where it is falling down.
04 Jan 2023 10:03 AM
It could be that is in the process of being transferred so I would give it a few more hours or at least until the end of the day as you should receive a notification from Sky when this has been completed.
You might want to also check that the number is correct on your device itself:
If this is an iphone go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone.
If it is an Andriod phone go to About Phone > My Phone number, change it and reboot the phone.
04 Jan 2023 10:07 AM
I have checked the settings and the number is correct. As i mentioned I can call out on the new phone and text. The only thing i cannot do is receive calls. I tried calling from another cell but goes to EE voicemail...
I guess it is still in process on being transferred as my EE device and sim are no longer working.
04 Jan 2023 10:25 AM
Posted by a Superuser, not a Sky employee. Find out moreI would leave it until this time tomorrow to see if it corrects itself, the fact you haven't received a notification yet suggests that the number transfer might not have fully been completed just yet.
20 Mar 2024 12:47 PM
I also have this problem and it has been like it for 3 weeks, had a replacement sim aswell and it still doesn't work
