Discussion topic: Going away
Message posted on 21 Jun 2025 02:53 PM
Going away
Will I get charged using my phone away?
Message posted on 21 Jun 2025 03:00 PM
Re: Going away
Presumably you mean abroad. Where are you going?
Message posted on 21 Jun 2025 03:01 PM
Re: Going away
Greece
Message posted on 21 Jun 2025 03:05 PM
Re: Going away
So, you will be charged £2 for every 24 hours to access your current allowance. Calls to local numbers are still charged at international rates.
Be aware of what they call accidental roaming whereby you connect to a nearby Albanian mast if you're near the border and you'll incur lots of charges. .
Message posted on 21 Jun 2025 03:11 PM
Re: Going away
Can I put a spending cap on my phone?
Message posted on 21 Jun 2025 03:14 PM
Re: Going away
@Tasha60 Follow the relevant instructions on the link below
https://www.sky.com/help/articles/sky-mobile-spend-caps
Message posted on 21 Jun 2025 04:04 PM
Re: Going away
Your spend cap needs to be high enough to cover your stay at £2 per day otherwise you will have issues using your phone.
