Discussion topic: Galaxy a35 charger
Message posted on 16 Sep 2024 03:23 PM
Galaxy a35 charger
I just received a new galaxy a35 and this is the charger they've sent. No plug and it's the same at each end with no USB part. Is this right? Am I missing something? Not sure how to charge!
Message posted on 16 Sep 2024 03:27 PM
Re: Galaxy a35 charger
Apple and Samsung and possibly other manufacturers have not supplied these for a good few years now. They want you to use an old charger or source one yourself.
Message posted on 16 Sep 2024 03:31 PM
So I have to buy a specific plug? I'm changing from iPhone to galaxy and the end of this plug doesn't fit into the apple plugs
Message posted on 16 Sep 2024 03:33 PM - last edited: 16 Sep 2024 03:34 PM
@Var8 wrote:So I have to buy a specific plug?
Yup. I would assume it's USB-C (which Apple have switched to as well)
Message posted on 18 Sep 2024 11:19 AM
Phone manufacturers are moving away from including a charger (Apple hasn't included one for some time) as they claim people most likely will have a charger from a previous device or a compatible plug which can be used instead.
The cable shown is a USB-c to USB-c so you'll require a USB-c charger.
I don’t work for Sky.
If I have helped then please leave a like.
