Discussion topic: Galaxy a35 charger
This message was authored by: Var8
Galaxy a35 charger
5D5AC9D4-2416-4659-BE3F-C9FC69509476.jpegI just received a new galaxy a35 and this is the charger they've sent. No plug and it's the same at each end with no USB part. Is this right? Am I missing something? Not sure how to charge!
Re: Galaxy a35 charger
@Var8
Apple and Samsung and possibly other manufacturers have not supplied these for a good few years now. They want you to use an old charger or source one yourself.
Avatar for Var8
So I have to buy a specific plug? I'm changing from iPhone to galaxy and the end of this plug doesn't fit into the apple plugs
Yup.   I would assume it's USB-C (which Apple have switched to as well)
This message was authored by: twilight+princess
Phone manufacturers are moving away from including a charger (Apple hasn't included one for some time) as they claim people most likely will have a charger from a previous device or a compatible plug which can be used instead.
The cable shown is a USB-c to USB-c so you'll require a USB-c charger.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
