Discussion topic: Estimate not compatible with device
This message was authored by: Andrewandfraser
Esim not compatible with device will sky change to nano sim
Re: Estimate not compatible with device
@Andrewandfraser
Have you activated the esim ?
Avatar for Andrewandfraser
Level 0 icon
I tried to install the estimate from the email sky sent but phone says incompatible with this device
@Andrewandfraser
If you haven't activated it then you will not be charged for it so you can order yourself a physical sim acrd here by selectimg it after picking a plan:
https://www.sky.com/shop/mobile/plans
Level 0 icon
Thankyou so much
