Discussion topic: Estimate not compatible with device
This message was authored by: Andrewandfraser
Message posted on 23 Sep 2026 09:55 PM
Esim not compatible with device will sky change to nano sim
Find out more
Message posted on 23 Sep 2026 10:05 PM
Re: Estimate not compatible with device
Have you activated the esim ?
Message posted on 23 Sep 2026 10:07 PM
I tried to install the estimate from the email sky sent but phone says incompatible with this device
Find out more
Message posted on 23 Sep 2026 10:11 PM
If you haven't activated it then you will not be charged for it so you can order yourself a physical sim acrd here by selectimg it after picking a plan:
https://www.sky.com/shop/mobile/plans
Message posted on 23 Sep 2026 10:19 PM
Thankyou so much
