Discussion topic: Does my current sim automatically cancel when I order a replacement sim?
This message was authored by Jade2022 This message was authored by: Jade2022
Morning,
I have ordered a replacement sim, will this automatically cancel the current sim or do I still need to call up to declare as lost?
Re: Does my current sim automatically cancel when I order a replacement sim?
When you activate the replacement the one it is replacing will automatically be cancelled.
Jade2022
Thank you for your reply, but do you know if the sim will still be working until that point? Or do I still need to freeze it? I hoped maybe by ordering a replacement this would happen automatically?
This message was authored by 63johnw This message was authored by: 63johnw
Hi @Jade2022  the old sim will remain active until the new one activates or you call sky to cancel it.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
