Discussion topic: Do I need a sim with non mobile products
This message was authored by: NickM92
Message posted on 13 Dec 2024 09:27 AM
I already have an iPhone with a sim but I have just ordered an iPad.
I did not add a plan as I will only use it with WiFi. Will I be able to use the iPad without an eSIM or will it be locked? I don't want to pay for another plan that I won't use.
Find out more
Message posted on 13 Dec 2024 09:31 AM
Re: Do I need a sim with non mobile products
Yes, I believe all Sky iPad's are cellular capable but you can just use WiFi fine.
(It just means you've probably paid more for the device than you needed to as you didn't need a cellular version)
