Discussion topic: Contacts showing 'unknown' on incoming calls
This message was authored by: Soo+Cee
since last week all of my contacts incoming calls suddenly started showing as 'unknown'.  I took phone to phone shop and they tried two different other providers sims in the phone.. both showed the contact name.  They suggested I get a new sim from Sky Mobile.  Got a new sim and again all of my contacts show 'unknown'.  I have spent over and hour this afternoon with an agent going over and over settings  and it is still the same.  Sadly I am going to have to look for a new provider if this isnt resolved.
Re: Contacts showing 'unknown' on incoming calls
@Soo+Cee
Have you recently returned from abroad ?
Ok, but you're just telling other customers here.
What sort of phone?
Have you tried switching between WiFi calling on/off?
Avatar for Soo+Cee
No haven't been out of UK for 7 years
Avatar for Soo+Cee
Yes.  After a long call with a sky tech the only last resort suggestion was 'try' factory reset - which I won't be doing because I'm not confidentabout  backing up everything and getting it all back onto the phone.
Looks like I will have to leave Sky mobile at end of contract 🙁
What sort of phone?
Avatar for Soo+Cee
Motorola G85.
Yes tried that. It did not change the problem. Thank you for replying.
