Discussion topic: Conditional call forwarding
This message was authored by: pjsmummy
How do I turn off conditional call forwarding. Tried all google advice. What even is it.
Re: Conditional call forwarding
Hi @pjsmummy  this is from sky
"How to set up call forwarding
  1. Go to Device Support.
  2. Select your device make and model.
  3. Search for 'call diverts' and follow the instructions.
Charges
You can set your phone up to forward calls to another UK mobile (07)* or UK landline (01, 02, 03) number.
The charge for a forwarded call is the same as if you made the call from your Sky Mobile to the forwarded number. For example, if you have Unlimited Calls & Texts, forwarded calls to a UK mobile (07)* or UK landline (01, 02, 03) number will be inclusive.
For details of charges for calling a UK mobile or landline while abroad, see the 'Roaming' section of the Sky Mobile tariff guide.
*Excludes indirect access and 070/076 numbers."
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
