Discussion topic: Charges for Dominican republic
This message was authored by: Carly44
How much will I get a charged using my phone in dominican republic
Avatar for Carly44
Level 0 icon
Re: Charges for Dominican republic
Do I get charged daily?
@Carly44  A Full list of charges can be found here
The £2 daily charge doesn't apply as it is a "Rest of the world" destination so these high charges apply:
£2.16 per mb of Data (not Gb)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
Hi @Carly44  it will be expensive to use roaming in the Dominican Republic. To avoid charges it's best to turn off roaming and mobile data in your phone settings then activate flight mode before leaving the UK. If you wait until you are in the air or landed then you will incur charges. Once there just turn on WiFi to use free local WiFi.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
