Discussion topic: Does not charge when plugged in
This message was authored by: Dbuell
Just have a question about my phone when I plug it into the charger it does not charge anymore the light doesn't even come on to indicate that it is charging what can I do
Re: Does not charge when plugged in
@Dbuell
The obvious question is have you tried another charger in case yours is faulty?
Hi @Dbuell also check the charging port on the phone for fluff.
All Opinions Are My Own
Avatar for Dbuell
Yes have tried a few different charger's and different outlets, also took the back off removed battery and everything was clean and looked good, maybe it has something to do with the battery, might need to be replaced... thank you for your help, maybe i need to upgrade..
What phone do you have @Dbuell  and how old is it ?
Avatar for Dbuell
It's the red sky device and I'm sure it's pretty old I'm not sure when I got it
If it's that old @Dbuell  then it could have just died, phones don't last forever so you may have to get a new one now.
