Discussion topic: 4G signal not loading
Message posted on 17 Sep 2024 05:41 PM
I have been having issues with sky 4G for a while now. It says iv got signal and nearly always full signal with 4G but nothing loads on safari and can't send WhatsApp's or do anything that involves using mobile data. I'm usually outside and this doesn't just happen in my small hometown it happens in bigger places too! Has anyone had the same issue?
Message posted on 17 Sep 2024 05:50 PM
							Re: 4G signal not loading
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
Message posted on 17 Sep 2024 06:00 PM
No known issues in my area
Message posted on 17 Sep 2024 06:03 PM
Does the same happen if you change the data setting to 3G ?
Message posted on 17 Sep 2024 06:05 PM
I can't change to 3G data setting?!
Message posted on 22 Aug 2025 11:28 PM
Happens to me if on iPhone go to settings then mobile service then data options and click data and voice enable 3G should work
